7 juin 2013, 03:01 UTC−4
Hi Ramona,
first, I think you should apply your sine wave as force as follow: sin(2*Pi*f[1/s]*t), unless you want to modulate your excited wave with Hanning window then you will need to multiply with Hanning function.
second, transient analysis(time-dependent) is more suitable than frequency analysis your case especially for thin layer elements where the expected wave is type of guided waves like Lamb wave.
Good Luck
Hi Ramona,
Good Luck
Henrik Sönnerlind
COMSOL Employee
7 juin 2013, 04:03 UTC−4
Note that in frequency domain, the time dependence is implicit. This means that if you write a load as 17[N], it actually means 17[N]*cos(2*pi*f).
In frequency domain, the assumption is however that it is a steady state situation, which contradicts your statement about "5 cycles".
In a time domain analysis the 'Low-Reflectiing Boundary' boundary condition can be used to suppress reflections of outgoing waves. It was introduced in version 4.3
Henrik
Henrik
7 juin 2013, 10:19 UTC−4
Hi Nadon,
thanks for your suggestions.
I apply my sine wave as a fixed displacement as follow: A[m]*sin(2*Pi*f[1/s]*t). I want to simulate a rigid body vibrating in touch with the thin layer.
If I apply only one pulse (see the attached figure called one_pulse) I can see this pulse propagating inside the thin layer (I have ploted the y-displacement in function of time for different distances from the source). If I apply a burst of 5 cycles (I have changed only the number of pulses) I can't see these 5 cycles propagating inside the medium. It looks like a bad sampling (see the attached figure burst_5cycles).
For both simulations I have used a time step of 1/(20*freq) and a maximum element size of wavelength/20.
Many thanks.
Ramona
Hi Nadon,
Many thanks.
Ramona
7 juin 2013, 10:23 UTC−4
Dear Henrik,
thanks for the suggestions about the frequency domain.
I am mainly interested in the time-dependent analysis.
I wanted to perform the frequency analysis only in order to use the PML. I am using the Structural Mechanics Module of Comsol 4.0, can you suggest a technique to apply non-reflecting boundary conditions in the time-dependent analysis?
I would like to understand which wave modes propoagate inside the medium. I was thinking to perform an eigenfrequency analysis but in this case the bodt is free and without load. I would like to apply a source of displacement and constraints on the edges.
Many thanks.
Ramona
Dear Henrik,
Many thanks.
Ramona
