Error: Undefined value found.
Posted 6 mai 2013, 17:43 UTC−4 RF & Microwave Engineering Version 4.2 0 Replies
I am simulating a nano antenna in RF module and I get this error:
- Detail: NaN_or_Inf_found_when_solving_linear_system_using_SOR
I also simulated the same model in 2D axisymmetric with the same frequency and the results were fine. Since I needed to use a different E-field as my source and the model was not symmetric anymore, I had to use 3D simulation. Moreover, I had some difficulties in meshing but I finally found a way to do the meshing without any errors. However, I only can change my mesh elements a little.
Since I used very dense meshes, does anyone know why I see this error?
Thank you.
Hello Zahra Mardy
