Initial values error using mapped mesh
Posted 30 avr. 2013, 15:37 UTC−4 Mesh Version 4.3 1 Reply
Every time I try to use a mapped mesh for a time dependent simulation I have the following error :
The following feature has encountered a problem :
failed to find consistent initial values.
System matrix is zero.
Last time step is not converged...
It is weird because when I run the same simulation with a mesh generated by default, everything works fine.
My geometry is more or less a rectangle (3D).
Is there anything special to do with the initial condition when a mapped mesh is used ? I don't find anything on the web.
Thank you for your help.
1 Reply Last Post 1 mai 2013, 02:04 UTC−4
