expression for analytic function for ferro-fluid
In "magnetic drug" problem, if i actually use the ferro-fluid instead of taking it's mass fraction as 0.1, what would be the expression for analytic function? According to my understanding, we don't need pump for flow of ferro-fluid under the effect of magnetic field and it's velocity depends on the temperature gradient of the fluid.For that i m providing a constant flux at the lower surface of the channel and eventually ferro-fluid will take away this heat
0 Replies Last Post 21 avr. 2013, 02:58 UTC−4
Hello Harry Garg
