Settings for simulating static or rf field between metallic contacts
Hi, I'm a new Comsol user and I'm interested to simulate the 2d field between two electrodes on a substrate. The electrodes can work at low but also at high frequencies. I've been able to draw the metallic contacts on top of the substrate but I don't know how to put a voltage between the two contacts in order to create an electric field between them. Can someone give me an hint?
1 Reply Last Post 4 avr. 2013, 17:03 UTC−4
Posted: 1 decade ago 4 avr. 2013, 17:03 UTC−4
check the lumped Terminal / Ports BC's (Boundary conditions). And take a look at some of the model library models, as well as the videos on the main web site, these are great to learn from
Hi check the lumped Terminal / Ports BC's (Boundary conditions). And take a look at some of the model library models, as well as the videos on the main web site, these are great to learn from -- Good luck Ivar
