Spiral 3D inductor Geometry
Hello
I am trying to simulate a 3D spiral inductor, but I cannot find the right geometric shapes given in Comsol 4.3a to build this coil. I have attached an image of the intended coil I want to build
I have tried using Helix but the geometry is completely different from the spiral inductor.
Any thoughts that how I can simulate it or I have to import it using some other software. Suggestions and advices are welcomed
5 Replies Last Post 7 juin 2016, 10:05 UTC−4
Josh Thomas Certified Consultant
Posted: 1 decade ago 2 avr. 2013, 09:40 UTC−4
Khalid,
Have you considered defining parametric curves? Right-click on Geometry 1 and select Parametric Curve. Then, in the edit field you can define expressions for your x and y coordinates based on a parameter s. You will need to know/develop the mathematical equation for the spiral edges in this case. Then, you can use Bezier Polygon line segments to connect the ends. And, then use a Conver to Solid operation to convert the edges into a solid body.
There may be a simpler way to do this, but this is the first that comes to mind.
Josh Thomas
AltaSim Technologies
Khalid, Have you considered defining parametric curves? Right-click on Geometry 1 and select Parametric Curve. Then, in the edit field you can define expressions for your x and y coordinates based on a parameter s. You will need to know/develop the mathematical equation for the spiral edges in this case. Then, you can use Bezier Polygon line segments to connect the ends. And, then use a Conver to Solid operation to convert the edges into a solid body. There may be a simpler way to do this, but this is the first that comes to mind. Regards, Josh Thomas AltaSim Technologies
Posted: 1 decade ago 2 avr. 2013, 09:53 UTC−4
Khalid,
is this similar to what you need?
Cheers
Edgar
Edgar J. Kaiser
www.emphys.com
Khalid, is this similar to what you need? Cheers Edgar -- Edgar J. Kaiser http://www.emphys.com
Posted: 1 decade ago 3 avr. 2013, 04:58 UTC−4
Khalid,
Cheers
Edgar
Edgar J. Kaiser
www.emphys.com
Yes its quite the same, except the number of turns are higher than this.
Regards
Khalid Hameed
[QUOTE] Khalid, is this similar to what you need? Cheers Edgar -- Edgar J. Kaiser http://www.emphys.com [/QUOTE] Yes its quite the same, except the number of turns are higher than this. Regards Khalid Hameed
Posted: 1 decade ago 3 avr. 2013, 05:25 UTC−4
Khalid,
Josh Thomas
I have tried using archimedes spiral but that is different in geometry, in addition the equation given in most places are for 2D. I am trying to work on equation to get the geometry
[QUOTE] Khalid, Have you considered defining parametric curves? Right-click on Geometry 1 and select Parametric Curve. Then, in the edit field you can define expressions for your x and y coordinates based on a parameter s. You will need to know/develop the mathematical equation for the spiral edges in this case. Then, you can use Bezier Polygon line segments to connect the ends. And, then use a Conver to Solid operation to convert the edges into a solid body. There may be a simpler way to do this, but this is the first that comes to mind. Regards, Josh Thomas AltaSim Technologies [/QUOTE] I have tried using archimedes spiral but that is different in geometry, in addition the equation given in most places are for 2D. I am trying to work on equation to get the geometry
Posted: 8 years ago 7 juin 2016, 10:05 UTC−4
Wow,it dose help for me , thank you for your sharing. Best wishes!
