Diaphragm
I am trying to do simulation of air horn diaphragm,
Inputs:
Diaphragm dia and thickness and material property.
Input pressure on diaphragm.
Output:
Max deflection of diaphragm.
Kindly provide me steps involved in simulating said diaphragm.
Thanks in advance........
1 Reply Last Post 28 mars 2013, 03:18 UTC−4
Posted: 1 decade ago 28 mars 2013, 03:18 UTC−4
you could run "solid" but be sure you have a few elements acrss the tickness, attach fixed the circumference and apply a boundary load. Or you could try with shell physics, it solves quicker
Hi you could run "solid" but be sure you have a few elements acrss the tickness, attach fixed the circumference and apply a boundary load. Or you could try with shell physics, it solves quicker -- Good luck Ivar
