Identity and contact pair
Posted 26 mars 2013, 10:24 UTC−4 Low-Frequency Electromagnetics Version 4.3a 1 Reply
I am trying to build a model in which it is not contacting in geometry but continuous in physical quantity between two surfaces in 3D model. So I use the "form an assembly" to build the model and define a identity pair between the two surfaces mentioned before. At the same time, I define a continuity boundary condition under the physics node and use the 'copy face' to establish the mesh for this identity pair.
However, I don't get the right result, for the voltage in the object is not gradiently distributes, which means that this identity condition setting is not correct.
But when I use the contact pair instead, I get the result which I need.
Thank you!
Thank you!
1 Reply Last Post 26 mars 2013, 13:02 UTC−4
