Pulsed Jet
Ndiaye Abdoulaye Séga
I'm trying to make a pulsed jet for a tilted Micro Jet for flow control. I want to ask you guys if it's possible to make it, how can i do it?
Salut,
Je suis entrain d'essayer de réaliser des jets pulsés sous comsol, j'aimerais savoir comment on peut les réaliser jusque là j'ai pas encore trouver de solutions.
4 Replies Last Post 25 mars 2013, 08:40 UTC−4
Posted: 1 decade ago 25 mars 2013, 05:19 UTC−4
you can apply functions of "t" instead of only scalars in any entry of COMSOL, just as COMSOL expects full fields (i.e.for a HT case T(x,y,z,t)) and not only a scalar value
Hi you can apply functions of "t" instead of only scalars in any entry of COMSOL, just as COMSOL expects full fields (i.e.for a HT case T(x,y,z,t)) and not only a scalar value -- Good luck Ivar
Posted: 1 decade ago 25 mars 2013, 05:31 UTC−4
Hi and thanks for you answer, but I need to couple "Speed + Frequency", the goal is to control the fluid flow by using a pulsed jet with a defined frequency.
Thanks again
Hi and thanks for you answer, but I need to couple "Speed + Frequency", the goal is to control the fluid flow by using a pulsed jet with a defined frequency. Thanks again
Posted: 1 decade ago 25 mars 2013, 08:19 UTC−4
but do you intend to sole in the time domain ?
in which case you can add a parameter for the average speed and one for the pulsing strength and time/period
In frequency domain it's probably tougher as the pulses are not really "periodic"
Hi but do you intend to sole in the time domain ? in which case you can add a parameter for the average speed and one for the pulsing strength and time/period In frequency domain it's probably tougher as the pulses are not really "periodic" -- Good luck Ivar
Posted: 1 decade ago 25 mars 2013, 08:40 UTC−4
Why not I'm going to try it this way and i'll be back .
Hi Why not I'm going to try it this way and i'll be back . Thanks
