How to calculate the impedance
Hi everyone,
I'm trying to calculate the impedance after feeding my set-up with a constant voltage.
As I have frequency-dependent parameters (relative permittivity and conductance), I expect complex values.
Is there any option to right away calculate the impedance in COMSOL?
Or do I first have to calculate other values, e.g. current density?
My problem is that I can only find the options: Average, Integration, Maximum and Minimum as regards the simulated voltage plot.
Thank you!
4 Replies Last Post 14 mai 2013, 05:47 UTC−4
Posted: 1 decade ago 22 mars 2013, 07:02 UTC−4
if you use the lumped ports / terminal you get the global values predefined
Hi if you use the lumped ports / terminal you get the global values predefined -- Good luck Ivar
Posted: 1 decade ago 22 mars 2013, 08:09 UTC−4
Thank you!
I was able to calculate resp. plot the impedance. But to my surprise it turned out to be constant...
As my potential is neither a constant according to my simulation, I'm a bit flabbergasted.
Do you by chance know whether COMSOL has any restrictions with the calculation of currents?
That would help me a lot!
Thank you! I was able to calculate resp. plot the impedance. But to my surprise it turned out to be constant... As my potential is neither a constant according to my simulation, I'm a bit flabbergasted. Do you by chance know whether COMSOL has any restrictions with the calculation of currents? That would help me a lot!
Posted: 1 decade ago 22 mars 2013, 08:14 UTC−4
check your BC settings, you might have missed something there, and dump more variables visa the derived variables to be sure the model really behaves as you expected ;)
I haven't really caught COMSOL with "severe" formula errors since back in 4.0, 4.1 time ;) So I tend to trust the latest versions
Hi check your BC settings, you might have missed something there, and dump more variables visa the derived variables to be sure the model really behaves as you expected ;) I haven't really caught COMSOL with "severe" formula errors since back in 4.0, 4.1 time ;) So I tend to trust the latest versions -- Good luck Ivar
Posted: 1 decade ago 14 mai 2013, 05:47 UTC−4
Hi Ivar,
I am new to comsol, can you please help me how too plot impedance vs frequency plot.
Hi Ivar, I am new to comsol, can you please help me how too plot impedance vs frequency plot.
