Problem with model 8649 plasma module
Posted 11 mars 2013, 17:11 UTC−4 4 Replies
Hi ,
I was trying to duplicate www.comsol.com/showroom/documentation/model/8649/ this model. I’m using Comsol 4.3, So I downloaded the corresponding files and Pdf. When I started following the same steps that’s on the instruction, I got following problems
· At first in model wizard I did up to number 5 But I couldn’t find preset studies as it says in number 6. There was just studies section and within which there was no Frequency-Transient.
In this point I selected frequency domain under custom studies which was available, The instruction worked fine up to specifying “Initial value I” but after that in Coil group domain section I couldn’t find “Coil group domain” in “magnetic field” under domain setting section. So I couldn’t proceed it further
Could you please find out what was the problem, is it problem with my doing or your instruction set. Please let me know
4 Replies Last Post 12 sept. 2016, 16:24 UTC−4
