Meshing problem with very thin Layer, sourrounded by air.
I'm modelling a spiral inductor on a PCB. The height of the copper layer is only 70 µm. Between the turns is an air gap of 200 µm. The inductor is sourrunded by an air domain and an infinite element domain.
The copper can meshed fast with a free Triangular mesh and a swept mesh. But I'm having problems with meshing the sourrunding air. I tried various mesh sizes but none of them worked.
I read that i might be possible to reduce the dimensions of the copper and build a layer with a zero thickness. But I need also the ohmic resistance of the inductor. So i think this not a solution.
Please help me with this problem.
3 Replies Last Post 20 mars 2013, 16:24 UTC−4
Posted: 1 decade ago 6 mars 2013, 10:51 UTC−5
you should slice your "air" at the thickness of the coil (in Z direction) so you have a thin slice in the middle of your model then mesh that one fully wit a boundary triangle and a sweep, finalise with thet for the upper and lower part. Normally the PML / INF mesh section should be structured mesh elements
Its often better to cut up your model (you could work with a symmetry plane two, in the middle of the coil height, it makes the model smaller, solve quicker and debug quicker
Hi you should slice your "air" at the thickness of the coil (in Z direction) so you have a thin slice in the middle of your model then mesh that one fully wit a boundary triangle and a sweep, finalise with thet for the upper and lower part. Normally the PML / INF mesh section should be structured mesh elements Its often better to cut up your model (you could work with a symmetry plane two, in the middle of the coil height, it makes the model smaller, solve quicker and debug quicker -- Good luck Ivar
Posted: 1 decade ago 7 mars 2013, 05:16 UTC−5
Hi Ivar,
thank you very much for your advise. It worked! Finally I was able to mesh the model with the additional air slice.
But now im fighting with the convergence of my solution. I'm trying to calculate the inductivity with the mef module.
Unfortunately the solution does not converge. I tried various refinements, but this didnt work.
Dou you know other possibilties to improve the model to reach convergence ?
kind regards
Marius
Hi Ivar, thank you very much for your advise. It worked! Finally I was able to mesh the model with the additional air slice. But now im fighting with the convergence of my solution. I'm trying to calculate the inductivity with the mef module. Unfortunately the solution does not converge. I tried various refinements, but this didnt work. Dou you know other possibilties to improve the model to reach convergence ? kind regards Marius
Posted: 1 decade ago 20 mars 2013, 16:24 UTC−4
as often a fine enough mesh (= reasonable discretization) is a "must" else, often its easier to start with 1-2 turns, then extrapolate by "addition" to N turns
Hi as often a fine enough mesh (= reasonable discretization) is a "must" else, often its easier to start with 1-2 turns, then extrapolate by "addition" to N turns -- Good luck Ivar
