2 mars 2013, 02:54 UTC−5
check the internal variables of COMSOL, you have the ut and utt, implicit derivatives of the dependent variables.
But you can also couple via u (displacements) on the boundaries, no ?
Rahul Kishor
Semiconductors
3 mars 2013, 23:10 UTC−5
Hi Ivar,
Could you please let me know as to what "coupling via u displacement" means...Is it similar to what I have done- ie
v= dU/dt , where v is the fluid velocity and U is the displacement of the piezomaterial......
When I set the above condition and compute.It throws the error-"Pointwise constraints for time derivatives are not supported."
Rahul Kishor
Hi Ivar,
Rahul Kishor
4 mars 2013, 01:15 UTC−5
but on which "entity" are you applying your velocity ? It looks like you do it on a "point", COMSOL has only derivatives on boundaries, as most edges and points/vertex are singularities the the FEM math sens
Rahul Kishor
Semiconductors
10 mars 2013, 11:21 UTC−4
Hello Ivar,
I have applied it along the boundary wall (interface between the fluid and the piezoelectric domain)......ie I have set in the "wall" - a moving velocity with the x component as ut and the y component as vt (where u and v are the dependent variables or the displacements in the pzd domain)......
Is there some workaround for it?
Rahul Kishor
NTU, Singapore
Hello Ivar,
Rahul Kishor
NTU, Singapore
10 years ago
11 août 2015, 22:35 UTC−4
Hi Rahul,
Did you get to solve this issue?
Thanks!
Hi Rahul,
Thanks!
