I export only S11 as S Parameter what about s12,21,22 ?
Posted 28 févr. 2013, 09:06 UTC−5 Version 4.3 17 Replies
you can post the file to the forum. Clear mesh and solutions to keep it small.
Cheers
Edgar
your model has only one port, so the 2-port components of the S-matrix cannot be available. I don't know what the function of your assembly is (resonator?, filter?). If it is meant to have input and output you must configure two ports respectively, one of them excited typically. Then you will see S12, S21 and S22 in the results.
Greetings, also from Germany,
Edgar
I haven't worked with SPICE netlists so far but there were contributions on the forum about that. I still don't understand how your device should work as a two port device in a circuit.
The way you defined the port it works as a shorted transmission line, like a 'Lecherleitung' only twisted, to save space?
Cheers
Edgar
I can't handle the SPICE netlist. Can you post a circuit diagram?
I see a shorted transmission line in your diagram. This is a one-port device and is typically and fully described by S11. The wave goes into the device and you want to know how much comes back and at which phase. This is all in S11.
Cheers
Edgar
I am sorry I can't contribute much about SPICE netlists in COMSOL. As I said I haven't done that so far. I hope I could explain why COMSOL is not producing two-port parameters the way you set up the model.
Cheers
Edgar
