meshing with Livelink
Posted 28 févr. 2013, 08:29 UTC−5 Interfacing, Mesh Version 4.3a 0 Replies
I have a major problem concerning the livelink.
I will explain to you:
I have a 2D plasma model of width 0.42m and height 0.144 m, I mesh the model with element size of order 10^-4m but at differnt sizes, so there are 646533 mesh elements in the domain.
When I use the matlab code to run comsol it gives 'solver run out of memory' , though I have saved the meshing in the model, and hence I do not create the meshing in matlab.
I tried two cases
1- use command : model.mesh('mesh1').run;
2-do not use command : model.mesh('mesh1').run;
To tell you that the code is written well it runs well when meshing is of order 10^-3 and without using the command model.mesh('mesh1').run;
What do you think?
I really need a solution to this problem since I have to run thousands of simulations.
Best Regards
Mervat
Hello Mervat Madi
