Transient magnetic field: mimic a wire
Hello, I have built a solid mechanics and magnetic fields multiphysics simulation. At a high level, the simulation includes a current-carrying wire (that generates a magnetic field), and a small, soft-magnet device at some distance from the wire. In the presence of the magnetic field, I study the deformation of the soft magnetic structure.
I now want to do this simulation in a transient domain, however I would like to eliminate the need to simulate the field from the wire. Instead, I would like to specify or easily generate a field with the same exact profile as the wire. The reason for this is that COMSOL is giving me trouble when I attempt to study the coupled physics involving the current carrying wire while in a transient domain. If I can instead specify a transient magnetic field (not coming from a wire, just a "magic" field, if you'd like), then I can avoid this problem.
I have made this field already by using the MFNC module and specifying the Hx Hy and Hz. It runs fine. However, I am wondering if there is/are better ways to do this?
Thank you.
1 Reply Last Post 1 avr. 2025, 20:12 UTC−4
Posted: 3 days ago 1 avr. 2025, 20:12 UTC−4
After first talking about the field from the wire, you then said that you have made the field by specifying Hx, Hy, and Hz, and it runs fine. So, if I understand that correctly, it sounds like you succeeded in specifying the "magic field" just as you wanted. Do you still envision that there is or should be a "better way"? Is there something else you would like to accomplish, but which isn't already working as you wish?
Reply
