20 févr. 2013, 01:56 UTC−5
check the doc on the solver. When COMSOL tries to solve a complex multi-physics problem, it can either solve it directly (all variables at a time, or try a segregated group approach (uses less ram but takes longer) by solving (in a loop) for some variables, then using the results to solve for the others. This approach is often better for highly non-linear models too
20 févr. 2013, 04:53 UTC−5
" Does the step in that line mean "time step"?"
No.
the value Step =[1,2,3] is due to the termination technique you have chosent. it has nothing about time step.
You find more here
model-> study1->Solver config->solver1->time-Depend -> segregated step -> "method and termination"
"So, will need to go through 288 steps??"
No.
Many more. Comsol gives you 288 results (in time for instance), but actually it solves the linear(ized) system many times more!
You find more here
model-> study1->Solver config->solver1->time-Depend ->"output" try to set the "time to store" == 'steps taken by solver'
As Ivar suggested: go through the manual :-)
Hope it helps,
Mattia
No.
You find more here
No.
You find more here
Hope it helps,
Mattia
