Solid Oxide Fuel cell (SOFC) model in fuel cell and batteries section
Dear All
I was using the solid oxide fuel cell (SOFC) model available in the COMSOL library of Batteries and Fuel cell. However in that model, I found that the user needs to input the inlet velocities at the anode and cathode respectively which remains unchanged.
In actual fuel cell the inlet velocities change depending upon the applied load. Only the respective stoichiometries (multiples of the actual consumed reactant) at anode and cathode remain constant. If anybody else has used the same fuel cell model and find this problem or if someone has used a different approach to vary the velocities, their assistance would very much be appreciated.
Regards
Abhishek Raj
1 Reply Last Post 15 juin 2016, 03:23 UTC−4
Hello Abhishek Raj
Alireza Setayesh hagh
Posted: 8 years ago 15 juin 2016, 03:23 UTC−4
Dear Mr Raj
I have been trying to validate the available comsol model result with experimental results both SOFC and
PEMFC that there has been huge difference between the model result and reference of model essay
outcomes is there any approach to solve this problem.
Best
Dear Mr Raj I have been trying to validate the available comsol model result with experimental results both SOFC and PEMFC that there has been huge difference between the model result and reference of model essay outcomes is there any approach to solve this problem. Best
