Display only Deformed Geometry in Results Node
This is a pretty basic question, but I have searched online and haven't been able to find an answer. I am performing a Static/Stationary structural simulation, and when I create a Results-Volume-Deformation node, I see the deformed geometry overlaid with the undeformed wireframe. Is there a setting to turn off the display of the undeformed geometry in this node?
1 Reply Last Post 24 janv. 2025, 18:33 UTC−5
Posted: 5 days ago 24 janv. 2025, 18:33 UTC−5
If you go up to the parent plot group you will see a check box labeled Plot Dataset Edges.
Reply
