LiveLink for MATLAB: exit a model
Every time one mphopens an mph file to do something about an mph file. But when this job is finished it is impossible to delete the mph file or save any changes to it. Is there any command to exit Matlab control, without closing comsol with matlab?
2 Replies Last Post 30 mars 2025, 23:40 UTC−4
Posted: 3 months ago 13 janv. 2025, 06:29 UTC−5
Hi Carl
See page 40 of the LiveLink for Matlab Users' Guide where the ModelUtil.remove command is described.
You may want to use this workflow: - Open the model using mphopen - Open the Comsol GUI by using the mphlaunch command - Now you can edit the model using either Matlab or the Comsol GUI and each environment can be used to save the model.
Lars Gregersen
Comsol Denmark
Hi Carl See page 40 of the LiveLink for Matlab Users' Guide where the ModelUtil.remove command is described. You may want to use this workflow: - Open the model using mphopen - Open the Comsol GUI by using the mphlaunch command - Now you can edit the model using either Matlab or the Comsol GUI and each environment can be used to save the model.
Posted: 1 week ago 30 mars 2025, 23:40 UTC−4
Dr Gregersen thank you
Reply
