Transient Heat Transfer
Hi everyone,
I am having difficulties solving a transient heat transfer problem, but the problem can be solved in stationary. I have attached the file. I am working on an analysis of hot pipes embedded in soil.
I am looking forward to hearing any feedbacks from any one of you.
Thanking you in advance.
2 Replies Last Post 14 févr. 2013, 11:01 UTC−5
Posted: 1 decade ago 14 févr. 2013, 05:31 UTC−5
Your model needs initial solution to solve transient situation. Select under "study1 => solver1 => dependent variables => initial values of variables solver for" solution where to start.
Best regards
Tero Hietanen
Hi, Your model needs initial solution to solve transient situation. Select under "study1 => solver1 => dependent variables => initial values of variables solver for" solution where to start. Best regards Tero Hietanen
Luke Gritter Certified Consultant
Posted: 1 decade ago 14 févr. 2013, 11:01 UTC−5
Gary,
Although you have a Time Dependent study step, the solver sequence contains a Stationary solver. I'm assuming that the solver sequence was generated with a Stationary study step, and then the Stationary study step was subsequently replaced by a Time Dependent study step. Whenever the type or number of study steps is altered in a study, delete the current solver sequence by right-clicking on Solver Configurations and selecting "Delete Solvers", and then generate a new solver sequence.
Luke Gritter
AltaSim Technologies
Gary, Although you have a Time Dependent study step, the solver sequence contains a Stationary solver. I'm assuming that the solver sequence was generated with a Stationary study step, and then the Stationary study step was subsequently replaced by a Time Dependent study step. Whenever the type or number of study steps is altered in a study, delete the current solver sequence by right-clicking on Solver Configurations and selecting "Delete Solvers", and then generate a new solver sequence. -- Luke Gritter AltaSim Technologies
