Failed to find the consistent initial values
Posted 12 févr. 2013, 00:20 UTC−5 Fluid & Heat, Heat Transfer & Phase Change, Computational Fluid Dynamics (CFD), Geometry, Materials, Mesh, Modeling Tools & Definitions, Parameters, Variables, & Functions, Results & Visualization, Studies & Solvers Version 5.1 3 Replies
Dear sir,
I am getting an error after solving as follows
"Failed to find the consistent initial values
- Feature : Time - Dependent Solver1 (sol1/t1)
- Error : Failed to find consistent initial values"
We suppose that the error is because of the fact that I am unable take back the results from 1440th time step to 0th time step (with an interval of 5 min each). Is that correct and how can I use the results of the 1440th minute back in oth minute for accurate values??
If not, what are the probable corrections for this error??
And, we have a prolonged query about the varying temperature of the fluid as it flows through the pipes. As the fluid flows through the pipe, the initial values of fluid temperature my vary from position to position. So, Can you let me know about how to incorporate this condition in the model of ours??
Thanking You sir.
Nithin
Thanking You sir.
Nithin
3 Replies Last Post 18 sept. 2015, 06:42 UTC−4
