Manipulate 1D line plot
I have a solution of y and x as a function of time.
I want to shift the values of y by subtracting it with the first value in the array of y, and then perform of 1D line plot.
Is there a syntax to write it COMSOL like "y - y(1,1)"?
Any help or suggestion.
Thank you
PS: I can export the data and then plot in MATLAB but I want to do it in COMSOL
1 Reply Last Post 15 déc. 2024, 11:38 UTC−5
Posted: 1 week ago 15 déc. 2024, 11:38 UTC−5
Oh yes, see https://www.comsol.com/support/learning-center/article/Examples-of-the-withsol-Operator-33781:
y-withsol('sol1',y,setind(t,1))
is a general form, such that you could not only subtract a value from your first solution (here assumed to be called 'sol1', but check), but from other studies too. This extracts the first time indexed value of y. Try it out...
René Christensen, PhD
Acculution ApS
www.acculution.com
info@acculution.com
Oh yes, see https://www.comsol.com/support/learning-center/article/Examples-of-the-withsol-Operator-33781: y-withsol('sol1',y,setind(t,1)) is a general form, such that you could not only subtract a value from your first solution (here assumed to be called 'sol1', but check), but from other studies too. This extracts the first time indexed value of y. Try it out...
Reply
