Temperature dependent boundary condition
I am trying to model heat transfer in a cryostat cooled by a pulse tube cryocooler. One approach is to set a fixed heat flux at the pulse tube's coldhead. However, more realistically, the cooling power (or heat flux at the coldhead) is a function of the temperature at both the first and second stage coldheads (see a capacity curve for example).
So my question is -- can I define the heat flux at a surface to be a function of the temperature at two locations in my model?
Thank you very much in advance, Joelle
1 Reply Last Post 23 oct. 2024, 04:06 UTC−4
Posted: 1 month ago 23 oct. 2024, 04:06 UTC−4
yes you can define the heat flux as the function of temperature as a variable and use it as a boundary condition at the location you want to set.
Reply
