Time-dependent simulation Shell (fluid interaction)
I an trying to use the fluid interaction module with a shell. The stationary study converge, but when i want to use the time-dependent step, it does not converge...
My system is like this : a tube with an inlet ( 0.1[m/s] * sin(t[1/s]) ) and an outlet ( pressure = 0 ). I fix the face at the inlet, to make the shell module to converge. I implement the materials for each module, and make a time dependent form 0 to 10, step 0.5.
I do not understand why the time dependent study does not converge... Can someone have a solution ?
Thanks a lot
0 Replies Last Post 13 sept. 2024, 12:04 UTC−4
Hello Symon Vanackere
Reply
