Meshing Internal Volume of CAD import
All,
I am trying to model fluid flow inside of a CAD object.
How do I create a domain inside the object that I can mesh?
I have capped all the openings.
John
1 Reply Last Post 29 janv. 2013, 01:48 UTC−5
Posted: 1 decade ago 29 janv. 2013, 01:48 UTC−5
if you imported a hollow tube, and capped the two ends, then you have a "domain" for the meshing and the fluid physics
But if your volume imported is not recognised as a "volume", only lines, you need perhaps to knit it together with a "convert to solid" geometry operation
Hi if you imported a hollow tube, and capped the two ends, then you have a "domain" for the meshing and the fluid physics But if your volume imported is not recognised as a "volume", only lines, you need perhaps to knit it together with a "convert to solid" geometry operation -- Good luck Ivar
