25 janv. 2013, 19:38 UTC−5
in v4 you find these under root-Globa-Definitions, or better: Model-Definitions-Functions, use the dynamic doc and search the HTML or PDF doc
28 janv. 2013, 09:21 UTC−5
I have tried to put the step function where I want to change the inlet concentration from c0 to 0 at time = 400s.
I defined the step function for concentration in the variables. It didn't not work for now. I guess my function is not correct or I need to add something more. I also attached my short simulation model here.
Thank you for your advice.
Pattamon
Pattamon
28 janv. 2013, 15:12 UTC−5
first of all your shape is very thin, with only 1 element across you do not resolve a lot, try to scale the vertical axis by i.e 100 in the mesh advanced tab.
Then your process is over in 4 seconds, your solver steps seem to be far too long, what about cutting your rectangle with a layer (geometry tab) at te half height of 0.3 um, then solve and look at the concentration along this central line in a line plot
Magnus Ringh
COMSOL Employee
29 janv. 2013, 02:57 UTC−5
The step function uses the concentration as the input argument (the switch), but that should be the time t. Also the step amplitude is the concentration c0, so I don't see why that value is multiplied with the step output in the variable intl: c0*step1((c0-0)[m^3/mol])
I think that you should use:
step1(t[1/s])[mol/m^3]
where "[1/s]" is used to make the argument unitless and the unit of the output is mol/m^3 for a concentration.
Also, perhaps the initial value should be c0 rather than 0? Now the initial value and the boundary condition for the concentration don't match at the start of the simulation.
Magnus Ringh, COMSOL
29 janv. 2013, 04:01 UTC−5
Thank you so much for all advices. It works now :)
Best Regards,
Pattamon
Best Regards,
Pattamon
