23 janv. 2013, 10:10 UTC−5
There are several options:
- Reduce mesh resolution
- Take advantage of any symmetries in the model
- Buy a faster computer ;-))
Cheers
Edgar
Cheers
Edgar
23 janv. 2013, 12:04 UTC−5
Thank for amswer..
BTW If both geometries are calculated on the same computer, so the quality of the computer should not play a role.
Thank for amswer..
23 janv. 2013, 13:04 UTC−5
no 3D has n^3 nodes versus n^2 for 2D and n for 1D its simple time consuming rule, now this is not the full story, but a good approximation.
Conclusion: always try to reduce the number of dimension of a model, and a model 10% correct in 2D gives better results than waiting for a 3D model to solve and anyhow not knowing if something is wrong and that one need to wait 2-3 solver times anyhow ;)
23 janv. 2013, 14:08 UTC−5
Thank you.
But I do not know if I'm wrong but I understood the problem that the model is slower in 3D than in 2D.
I should therefore reduce the 3D model?
And one more question what is Llimitfivar?
Thank you.
23 janv. 2013, 14:37 UTC−5
Yes a model will be far slower in 3D than in 2D because there is far more to calculate.
But I cannot tell you anything about that variable, I do not know that one ;)
Probably "Support" can tell (I'm not from COMSOL ;)
Have you tried to search the help and the pdf documents ?
23 janv. 2013, 14:54 UTC−5
I did try searching the help, but nothing.
I have another meaningless error:
Failed to evaluate variable Jacobian.
- Variable: mod1.AzY
- Geometry: 1
- Domain: 2
It is nonsense because it appears in the 2D model.
You do not have at least some e-mail address for such support?
Because when I write to support, no reply.
Thank.
- Geometry: 1
- Domain: 2
Thank.
23 janv. 2013, 16:08 UTC−5
its the one on the main web site, but recently you can ask for support cases via your login info (click on your name top right of the present web page or login first if your name is not there)
It would help if you explained a bit more which physics you are using, 2D, 3D, etc as there are a few thousand variables inside COMSOL and their name depends on the physics, the type of modelling etc, it's not easy for us out here to understand exactly what you are doing
The Jacobian is the matrix COMSOL uses to map the deformations and to sense where to push next step for the solver iterations, your BC must be continuous functions (or scalars) else COMSOL cannot estimate the Jacobian
