Combination of Fluid Flow and Heat Transfer
Hello everyone, I am a new member of this forum and also a fresh user of COMSOL. I hope I will be able to learn from and discuss problems with all of you. My first enquiry to the forum follows:
My scenario:
An embedded pipe with hot fluid flowing inside
Aim:
To find out how the heat is transferred from the pipe to the surrounding over time. hence to determine the positional temperatures in the surrounding, such as 1m or 2m away from the pipe.
I know how to model it easily only with a heated pipe being embedded, but I do not know how to model it with the hot fluid flowing inside the pipe.
I am looking forward to hearing your advice on how to model this scenario correctly.
Thanking you in advance.
2 Replies Last Post 21 janv. 2013, 22:25 UTC−5
Posted: 1 decade ago 21 janv. 2013, 01:05 UTC−5
I would propose that you study the conjugated heat Transfer (NITF) but as this is a multi-physics environment, that is rather heavy, it's worthwhile to start to study only HT, then only SPF (laminar flow), then the combination NITF
When you have solved correctly the others independently, then its easier to set up the NITF correctly
Debugging is far easier one physics at the time
Hi I would propose that you study the conjugated heat Transfer (NITF) but as this is a multi-physics environment, that is rather heavy, it's worthwhile to start to study only HT, then only SPF (laminar flow), then the combination NITF When you have solved correctly the others independently, then its easier to set up the NITF correctly Debugging is far easier one physics at the time -- Good luck Ivar
Posted: 1 decade ago 21 janv. 2013, 22:25 UTC−5
Thanks for your reply, Ivar.
I think I am doing alright with just the heat transfer part, I am now exploring in the fluid flow part.
Thanks for your reply, Ivar. I think I am doing alright with just the heat transfer part, I am now exploring in the fluid flow part.
