Issue with Thermal Expansion Simulation Using External Material
I am working on a simple geometry problem involving a rectangular solid where the temperature changes over the height of the structure. When I use the built-in linear elastic material model in COMSOL, I can easily add thermal expansion under the "Attributes" section in the Physics module. By defining the reference temperature (Tref) and the temperature (T), the simulation runs successfully, and I obtain the expected results.
However, when I attempt to use an external material with the same properties (including Tref and T), the results are zero, indicating that the thermal expansion effect is not being correctly applied. It seems that the thermal expansion needs to be activated or properly configured for the external material, but I am unsure how to do this.
0 Replies Last Post 18 juil. 2024, 16:16 UTC−4
Hello Sara Sarbaz
Reply
