Variable change with time
I have a question about variable change with time.
I try to make a mass transfer model. The inflow concentration change with time.
If t <= 1000s then C=1mol/m^3
else C=0
I upload the data and make a Interpolation Function. Function name: int1
Then I set the Inlet Concentration as int1. It shows int1 is not variable.
How can I make this kind of variable?
Thanks in advance
Dylan
2 Replies Last Post 19 janv. 2013, 17:01 UTC−5
Posted: 1 decade ago 18 janv. 2013, 02:08 UTC−5
if you make it a function you need to give it an argument as int1(t[1/s]). But I would propose that you use a step function from 1 to 0 at t = 1000 s with a smoothing of perhaps 1 sec, then enforce your time stepping algorithm to slow down and take a 2-3 points during the switch off (i.e. strict or intermediate stepping)
Hi if you make it a function you need to give it an argument as int1(t[1/s]). But I would propose that you use a step function from 1 to 0 at t = 1000 s with a smoothing of perhaps 1 sec, then enforce your time stepping algorithm to slow down and take a 2-3 points during the switch off (i.e. strict or intermediate stepping) -- Good luck Ivar
Posted: 1 decade ago 19 janv. 2013, 17:01 UTC−5
Thank you very much.
Dylan
Thank you very much. Dylan
