Force calculations on permanent cube magnet and coil
Posted 6 juil. 2024, 05:32 UTC−4 Electromagnetics 5 Replies
Dear All,
I had a quick question about my model attached,
I have a cube permanent magnet above a coil. The system is trying to model a cube magnet that has north and south faces along the x-axis, and is fixed at the center and free to rotate (z-axis) left or right based on the polarity changes of the coil when current direction is changed. I have three questions:
1- When you run the model, I would expect there to be a negative y-axis force, no/negligible z-axis force (as the magnet and coil are symmetrical) and an x-axis force either in +/- based on the polarity of the coil. I.e. the coil is trying to pull/rotate the cube magnet left or right based on the polarity of it. However, I seem to get a z-axis force, and the x-axis doesn't seem to mirror the force on the cube equally in the +- when the polarity of the coil changes. why is that? shouldn't I get a relatively equal force on the cube magnet in x-axis but mirrored based on the polarity of the coil?
2- In my 1-D line plots, why are the plots not continuous and are jumpy?
Really appreciate all your support!
Best, F
A few comments:
The mesh on and in the magnet is far too coarse for a good force calculation. Apply a dense custom mesh on the boundaries of the magnet. The coil may be ok but a higher mesh density won't harm. You will need to do a mesh convergence study to verify the mesh.
Instead of using such a huge air box, make it smaller and apply infinite element domains at the outer boundaries of the box. This way you can make the box much smaller and save much memory.
Cheers Edgar
-------------------Edgar J. Kaiser
emPhys Physical Technology
www.emphys.com
Thank you so much Edgar,
I am quite new with COMSOL, and I havent fully grasped the steps required to do better meshing optimization.
I tried doing a infinte element mesh for the air box, but doesn't seem to work. I tried the layer around the air box and used the infinite domain element, but the run time took so long and didn't seem to work for me.
I tried doing extra fine for the air box domain, and 0.1mm maximum size for the magnet but seems to take forever to build the mesh.
Could you please show me the steps I need to take? and how to do a mesh convergence study?
Does the air domain have to be very fine too?
Thank you so much for your support!
Best, F
There are examples in the application library showing the infinite element domains. For a mesh convergence study you define a parameter that multiplies with the mesh size parameters. You can then run a parametric sweep over this parameter.
In the forum I am happy to give hints, but I cannot afford the time to do the detail work.
www.emphys.com
Thank you, I totally understand, I really appreciate your hints.
Whats the benefit of a mesh convergence study?
If i try to do a mesh sweep on the cube would that work? and I can make the element sizes very small? Is a mesh sweep with one of the square faces a good way to do things?
Can I mesh the faces of the cube differently from the inside and body of the cube? is it worth doing that?
So is my inaccurate and misleading force calculations definitely a cause of meshing rather than something else I did incorrectly?
Best, F
You need the mesh convergence study to make sure the mesh is good enough and not too good to avoid high computational costs. See if the results remain (almost) constant at a certain mesh density. Regarding meshing details, you will need to try a few things. Check the documentation and examples.
www.emphys.com
Reply
Discussion Forum Rules and Guidelines
The goal of COMSOL Access is to provide a forum for you to communicate effectively with COMSOL as well as your colleagues within the multiphysics simulation community. This involves providing you with access to technical support and downloads of the latest {:comsol} software releases, as well as the ability to share your comments and work with other users of the {:comsol} software through forums such as the blog, discussion forum, and Application Exchange. In order to make this an efficient and pleasant experience for you and other members of COMSOL Access, we ask that you follow a few rules and guidelines.
When registering for COMSOL Access, you agree to provide your complete and truthful information for all fields requested on your COMSOL Access account registration page. You also agree to maintain the accuracy of all information associated with you on your COMSOL Access account. You agree to maintain your COMSOL Access account for use solely by you, not to share your username and password with anyone else, and to take appropriate precautions to restrict access to your username and password from others. Furthermore, you agree not to submit any information relating to your employer through your COMSOL Access account without your employer’s authorization. Should you use a COMSOL Access account associated with an employer, you agree to immediately discontinue using that account upon termination of that employment.
The moderators of the forums will remove any generally objectionable material as quickly as possible. You acknowledge that all posts made to these forums express the views and opinions of the author and not the administrators, moderators, or webmaster (except for posts by these people). Hence, they will not be held liable.
You agree not to post or link to any material that is abusive, obscene, vulgar, slanderous, hateful, threatening, sexually oriented, or that infringes upon or violates any third-party rights or any other material that may violate any applicable laws. You agree that you will not otherwise use your COMSOL Access account to violate or to assist anyone in violating any law. Engaging in any activity in violation of these COMSOL Access rules and guidelines may lead to you being immediately and permanently banned from COMSOL Access. The IP address of all posts is recorded to aid in enforcing these conditions. You agree that the webmaster, administrator, and moderators of the forums have the right to remove, move, or close any topic at any time as they see fit. As a user of COMSOL Access, you agree to any information you have entered into any of the forums being stored in a database.
You agree that you will not use your COMSOL Access account in violation of any applicable export control laws. You represent and warrant that you are not subject to any comprehensive sanction or embargo by the U.S. or any other country, nor are you identified on any list maintained by the U.S. government that identifies persons for which the U.S. maintains restrictions. Further, you represent and warrant that you are not subject to any restriction on the receipt of technology or products under the export control laws of the U.S. or any other country.
Basic Rules
- Flaming: Do not post any messages that harass, insult, belittle, threaten, or flame another member or guest. Debates are fine, but argue with the point, not the person.
- Trolling: Do not post with the purpose of starting a dispute. Note that a person disagreeing with your opinion is not considered trolling; keep it civil, even if you are sure that the other person is wrong. Anything seen as trolling will result in you being banned.
- Spamming: Posts without content or containing nonsense waste space and everyone's time. Spam will be removed from the forum.
- Offensive Posts, Links or Images: Do not use profanity, racial, ethnic, religious, or other slurs or any other offensive material.
- Advertising: Posting of advertisements for products or services, links to auctions, affiliate links, links to promote websites, and so forth is not allowed.
- Disclosure of Personal Information: Do not disclose any other member's email, real name, address, phone number, IP address, or other personal information. This includes posting contents of emails and private messages without the sender's consent. Do not bring personal disputes into the forums. Bans and warnings issued to other users are considered personal information.
- Misleading Titles: The subject line of the post should be as informative as possible about the content of the post. This also reduces the amount of duplicate posts.
- Thread Hijacking: Taking a thread off-topic to pursue one's own agenda is not permitted.
- Piracy: Do not upload, post, email, transmit, or otherwise make available any content that infringes upon any patent, trademark, trade secret, copyright, or other proprietary rights ("Rights") of any party. This includes COMSOL model files created by a forged or illegitimate license.
- Honesty: Users must provide truthful information in creating their COMSOL Access account.
These rules are subject to change. The moderators reserve the right to remove, edit, or move posts at their discretion. The COMSOL Access administrators will reserve the right to permanently remove a user account without notice if any of the rules are not followed. Particular services accessible with your COMSOL Access account may be subject to additional rules. You agree to comply with all rules applicable to each service you access through your COMSOL Access account.
Posting Guidelines
When posting, understand that you are trying to communicate with other people. Although many COMSOL Access members are not fluent in English, the official language of this forum is English.
Here are some important guidelines of language:
- Write in English.
- If you are familiar with LaTeX, please use this to write mathematical equations.
- Always do a quick check for spelling/grammar mistakes.
- Format your post in a legible manner. Use the Preview button often.
- Be concise and articulate as much as possible.
- Use the Enter key to create paragraphs.
- Capitalize correctly. It is difficult to read posts that are written entirely in uppercase or lowercase.
- Use correct punctuation. Avoid run-on sentences.
- Try to avoid using “text speak”, “net speak”, or slang. The purpose of language is to be understood.
- Never invent acronyms and use as few acronyms as possible. For example, write "COMSOL Multiphysics" and not "CMP".
- Review your post before publishing it. Try to catch typos.
- Please check to see if a topic has already been posted. Do not post multiple threads on the same topic.
Disclaimer
By submitting content to the forums, you hereby grant COMSOL a nonexclusive, royalty-free, perpetual, worldwide, and unrestricted license to reproduce, publicly display, publicly distribute, and prepare derivative works of the content. COMSOL hereby grants you a license to copy and/or use content from the forums solely for your own internal purposes. COMSOL provides the forum service for the benefit of our users to share content with the community. All content is provided "as is" without warranty of any kind, express or implied, including without limitation, warranties of merchantability, noninfringement, design, operation, and fitness for a particular purpose, and the entire risk as to the quality and performance of the programs is with you.
Neither COMSOL, the authors, nor the copyright owners of submitted materials warrant that the programs will be error-free, uninterrupted, virus-free, secure, and suitable for your needs, produce specific results, or that errors or failures will be corrected. Comments on supplied content should be sent to the author or copyright owner through the tools provided in the forums.
Suggested Content
- BLOG The Electromechanical Response of a Brake Design
- KNOWLEDGE BASE How to administrate a COMSOL Multiphysics Floating Network License and a COMSOL Server License on the same license server
- FORUM Calculating force from coil on permanent magnet
- FORUM pressure load by air expansion in cube
- KNOWLEDGE BASE How to Administrate Multiple Floating Network License Files on one License Server
