Approximation curve by an exponential
I would like to know if it's possible to approximate a curve by an exponential one determine and plot it on Comsol.
Thks
1 Reply Last Post 15 janv. 2013, 14:25 UTC−5
Posted: 1 decade ago 15 janv. 2013, 14:25 UTC−5
you can import the data into a interpolation file, then create an exp function and optimise the parameters to fit in a means square way to the data set, but it's somewhat an overkill to use COMSOL for that, you can also ask the interpolation function to approximate yor data, but I believe its limited to poloynomials
Hi you can import the data into a interpolation file, then create an exp function and optimise the parameters to fit in a means square way to the data set, but it's somewhat an overkill to use COMSOL for that, you can also ask the interpolation function to approximate yor data, but I believe its limited to poloynomials -- Good luck Ivar
