Plot an expression along a specific coordinate system
I defined a cylindrical system (r,phi,a) and I'd like to get the results along one of these specific coordinates.
Since all the direct results expressions are defined in cartesian coordinates (x,y,z). I would like my magnetic field along x "mf.Hx", as an example, to be expressed and shown along r.
I found that the way to do so seem to insert an expression in the plot expression setting. I found that the cylindrical system is included in the definitions window. But I can't find a way to have my expression calculated along r since I get an error. Also, I can't figure out which one to select from the list between "Base vector (sys2) a", "coordinate, a component (sys2.a)" or "coordinate transform to system (sys2)".
What should I do please ?
Thanks a lot
1 Reply Last Post 15 janv. 2013, 08:01 UTC−5
Posted: 1 decade ago 15 janv. 2013, 08:01 UTC−5
the cylindrical coordinates "sys2" (or 3 or 4 depending on how many you define) defines (sys2.r sys2.phi sys2.a) with something like a=z-Z0 r=sqrt((x-X0)^2+(y-Y0)^2) and phi=atan2((y-Y0),(x-X0) (pls check I might have got a sign wrong ;) with (X0,Y0,Z0) the origine of your
Still you need two write out your results fully with cylindrical coordinates in a similar way
You have also the coordinate transform matrix values sys2... as well as the inverse, check the Results tab and the doc for the full naming convention
Hi the cylindrical coordinates "sys2" (or 3 or 4 depending on how many you define) defines (sys2.r sys2.phi sys2.a) with something like a=z-Z0 r=sqrt((x-X0)^2+(y-Y0)^2) and phi=atan2((y-Y0),(x-X0) (pls check I might have got a sign wrong ;) with (X0,Y0,Z0) the origine of your Still you need two write out your results fully with cylindrical coordinates in a similar way You have also the coordinate transform matrix values sys2... as well as the inverse, check the Results tab and the doc for the full naming convention -- Good luck Ivar
