Edgar J. Kaiser
        Certified Consultant
                                1 year ago
                                18 juin 2024, 06:09 UTC−4
                        Updated:
                                1 year ago
                                18 juin 2024, 06:17 UTC−4
                                                    George,
There is no piezomagnetic domain in the solid node.
Cheers
Edgar
    Edgar J. Kaiser
emPhys Physical Technology
www.emphys.com
                            George,
Cheers
Edgar
                                1 year ago
                                18 juin 2024, 10:48 UTC−4
  George,
  Cheers
  Edgar
Okay but after put  a solid node ,i need two voigt matrix .Do you can tell me how to define two matrix ?Compliance  matrice,Voigt notatio and Piezomagnetic coupling matrix ,Voigt notation
                            >George,
>Cheers
>Edgar
                                Edgar J. Kaiser
                                1 year ago
                                18 juin 2024, 13:32 UTC−4
                                                    Yes, it seems that in that case of nonlinear magnetostriction the piezomagnetic domain is not required as the multiphysics coupling is doing the job.
Keep in mind that the Villari effect is not generating a magnetic field in the magnetostrictor. The mechanical strain modifies the magnetic properties of the material and this  modulates the DC bias field. Without the bias field, no magnetic field is generated.
    Edgar J. Kaiser
www.emphys.com
