How to know all the variables existing in MPH file via Matlab
I have a basic problem which may be simple for most users. I just want to do some further postprocessing for MPH results via Matlab. But, I don't know how to know all the variables existing in MPH file via Matlab. That is to say, for example, if there acturally exists a calculated datagroup denoted by "C" in MPH file, how can I know the "C" exists in Matlab? Otherwise, I cannot operate it via Matlab. It seems that the commands, "mphnavigator" and "mphmodel" can only list the all the objects in the MPH file. Is there a way to list the varialbes or the specific name of all the datagroups calculated in Cosmol ?
For example, If I have performed a COSMOL for Structure Mechanics analysis in order to get the deform gradient tensor, say F, the right Cauchy-Green tensor, say C, and the second PK stress, say S, corresponding to every element, in what way can I directly access the data via Matlab? Which command is responsible for that ?
Thanks for help!!
1 Reply Last Post 15 janv. 2013, 08:58 UTC+1
Posted: 1 decade ago 15 janv. 2013, 08:58 UTC+1
add this line at the end on you code:
[sz, dof,list,name,type] = mphgetp( model )
the varible 'name' contains your list. See the API guide for furhter information.
Hope it helps,
Mattia
Hi, add this line at the end on you code: [sz, dof,list,name,type] = mphgetp( model ) the varible 'name' contains your list. See the API guide for furhter information. Hope it helps, Mattia
