Coil Feature Magnetic Field Interface
Hi there, I'm trying to model a coil. I'm currently using the 5.5 version (build 359) and when I head over to right click on the magnetic field section, I don't see any coil features even though I believe they are supposed to be there. I was wondering what might be the problem. Thanks!
2 Replies Last Post 29 mai 2024, 14:24 UTC−4
Posted: 9 months ago 29 mai 2024, 13:25 UTC−4
Rachel,
could it be that you don't have the AC/DC application module? In this case only a few mf related items are available in the COMSOL main module.
Cheers Edgar
Edgar J. Kaiser
emPhys Physical Technology
www.emphys.com
Rachel, could it be that you don't have the AC/DC application module? In this case only a few mf related items are available in the COMSOL main module. Cheers Edgar
Posted: 9 months ago 29 mai 2024, 14:24 UTC−4
Hello Rachel,
I think Edgar is right. To check whether the license you are using includes the AC/DC Module, go to File > Licensed and Used Products.
Note that even without the AC/DC Module you will have an "AC/DC" folder in the Model Wizard; it is not an indication of whether the license includes the AC/DC Module (I know, it's confusing).
Jeff Hiller
Hello Rachel, I think Edgar is right. To check whether the license you are using includes the AC/DC Module, go to File > Licensed and Used Products. Note that even without the AC/DC Module you will have an "AC/DC" folder in the Model Wizard; it is not an indication of whether the license includes the AC/DC Module (I know, it's confusing). Best, Jeff
