Kristian Ejlebjærg Jensen
COMSOL Employee
11 months ago
29 mai 2024, 06:41 UTC−4
Updated:
11 months ago
COMSOL does not support integer optimization. IPOPT will change controls even though the sensitivity is zero, but in most situations, you can just fix the integer and perform a sweep over the optimization. It sounds like you only have a single integer parameter, so this ought to be a viable strategy.
Kristian E. Jensen
Technical Product Manager Optimization
Kristian E. Jensen
11 months ago
29 mai 2024, 11:38 UTC−4
Updated:
11 months ago
29 mai 2024, 11:40 UTC−4
Thank you for the reply, I will try that.
Is the incrementation of each parameter constant over the optimisation ? if so I could maybe find a scale factor that makes the step be 1
COMSOL Employee
10 months ago
11 juin 2024, 04:13 UTC−4
Updated:
10 months ago
11 juin 2024, 15:02 UTC−4
You can specify the increment in the Parametric Sweep, i.e. range(1,1,10) sweeps the value from 1 to 10 in steps of 1.
Kristian E. Jensen
Kristian E. Jensen
