Parametric sweep not being made/showing any plots
I encounter an issue when I try to perform a parametric sweep for my meshsize. I am trying to get a plot showing how it changes based on what meshsize one gets for each frequency in my plot (mainly the eigenfrequencies). How come my parametric sweep is not being performed or it is being performed but only showing one constant value? I will attach a picture of my sweep as well as my model file.
Thank you in advance!
2 Replies Last Post 17 mai 2024, 07:24 UTC−4
Posted: 8 months ago 16 mai 2024, 15:48 UTC−4
Merna,
You are plotting the mesh size parameter over frequency, which is of course a constant over the frequency sweep. I guess you rather want to plot some physical result quantity as a function of frequency for the range of parameter values. Each parameter value will then show the respective frequency response for this quantity.
Cheers
Edgar
Edgar J. Kaiser
emPhys Physical Technology
www.emphys.com
Merna, You are plotting the mesh size parameter over frequency, which is of course a constant over the frequency sweep. I guess you rather want to plot some physical result quantity as a function of frequency for the range of parameter values. Each parameter value will then show the respective frequency response for this quantity. Cheers Edgar
Posted: 8 months ago 17 mai 2024, 07:24 UTC−4
Thank you very much for your response Edgar.
All the best!
Thank you very much for your response Edgar. All the best!
