Obtain the coordinates of faces
Hello!
I'm using COMSOL with MATLAB, and I need to get the coordinates of the faces of my model. I'm using the following line: [info1, data1] = mphgeominfo(model, 'geom1', 'entity', 'face');
However, I'm encountering a problem because the geometry comes from an imported mesh, which results in the following error:
Error using mphgeominfo DATA output is not supported when the geometric model is defined by a mesh and entity is a face
Error in TestSelecAuto (line 72) [info1, data1] = mphgeominfo(model, 'geom1', 'entity', 'face');
How can I obtain the faces data in this situation?
Thank you, Vassili
0 Replies Last Post 16 mai 2024, 07:18 UTC−4
Hello Vassili DELINE
