Henrik Sönnerlind
COMSOL Employee
1 year ago
8 avr. 2024, 05:33 UTC−4
The difference between constraint groups and load groups is that loads only change the right hand side of the system of equations. If you change the set of constraints, you also get a new stiffness matrix. So they are not interchangable. When you can assign a constraint to both a load group and a constraint group, the constraint group is used for turning the constraint on and off. The load group can be used changing, for example, the value of a non-zero prescribed displacement.
Load and constraint groups are only supported by some study types.
Henrik Sönnerlind
COMSOL
1 year ago
9 avr. 2024, 10:09 UTC−4
Thank you. So may I confirm that in time dependent analysis load groups aren't supported?
Henrik Sönnerlind
COMSOL Employee
1 year ago
10 avr. 2024, 03:51 UTC−4
Updated:
1 year ago
10 avr. 2024, 04:06 UTC−4
That's correct. It is supported for the stationary types of analysis, that is Stationary and Frequency Domain.
Henrik Sönnerlind
COMSOL
1 year ago
11 avr. 2024, 03:33 UTC−4
Thank you for the confirmation Dr Sönnerlind
