Color saturation
Antonio Fernandez Dominguez
This is a quite naive question. I am trying to make an slice plot from a 3D simulation and I want to saturate the colors. When I do that using the Rainbow color palette, areas where the colors are saturated (values below the minimum and maximum I have defined) appear in white.
I want to change this and render in red the areas above the maximum and in blue those below the minimum.
How can this be done? I have been looking through the manuals and I haven't found any answer.
Antonio
1 Reply Last Post 22 févr. 2010, 13:03 UTC−5
Posted: 2 decades ago 22 févr. 2010, 13:03 UTC−5
You can export your model to Matlab, and try to find the trick which allows you to do what you are looking for. There are more options in Matlab.
I hope it helps and good luck!!
Cheers,
Hi, You can export your model to Matlab, and try to find the trick which allows you to do what you are looking for. There are more options in Matlab. I hope it helps and good luck!! Cheers,
