how to import a computed polynomial function in a Matlab script into a Comsol simulation?
Posted 31 janv. 2024, 11:03 UTC−5 12 Replies
Hello everyone,
I'd like to start by saying that I don't know much about this, in fact, almost nothing. I have an issue regarding the interaction between Matlab and Comsol, specifically in dynamically importing a polynomial function calculated in a Matlab script into a time-variable Comsol simulation.
To better explain the problem, I have uploaded three files:
A CSV file containing data to be interpolated in the Matlab script. Each row corresponds to different time instances, and the first row contains the points along x at which the quantity of interest was evaluated.
A Matlab script where, within a for loop, I analyze my CSV file. At each step of the loop, I obtain my polynomial function (string_polynomial), which I would like to import into Comsol.
The Comsol model containing my geometry. In particular, within the physics .mf with the Pointise Constraint function, I would like to impose the corresponding polynomial function for each timestep, calculated with the Matlab script.
It's precisely this step that is causing me problems. I'm not sure how to interface the two software tools and especially how to perform this "exchange" of polynomial functions for each timestep.
I assume that the number of timesteps in the transient study and the number of timesteps in the script (and thus in the CSV file) should be equal.
Thanks in advance to anyone who can help!
Hi Marianna,
I can't tell about the Matlab interface because I am not using it. You might consider to import the csv data directly into a 2D interpolation function in COMSOL and avoid the Matlab interfacing. This way you can call a function f(x, t) in the model. You have an interpolation in both dimensions, space and time.
Check the documentation about input formats of interpolation functions and about the way they interpolate to see if it is suitable for your project.
Cheers
Edgar
-------------------Edgar J. Kaiser
emPhys Physical Technology
www.emphys.com
Hi Edgar, many thanks for you suggest!
I have done some test but I didn't understand how I have to define my data. As I have read it's not possible used a grid with more 3 rows, is it correct? I have a file excel defined as in photo in which the yellow cells are the x coordinates and the rows from 2 to 6 are the number of timestep i.e. 1s, 2s, 3s...
How can I define a f(x,t) function in Comsol with my data?
Thank you in advance for your help! Marianna
Hi Marianna,
in the lines below the %Grid line you specify the nodes of your function, i.e the x and y values, or x and t in your case. So the first line would contain all the x values in the yellow line. The second line contains the t values, e.g. 1, 2, 3, etc. You don't need a third line because you only have two arguments in the function.
Below the %Data line you specify all the data values f(x, t) for the nodes in your function. Those are all the values in the white lines in your Excel sheet. They do not need to be structured in lines. This will be done according to the data under %Grid.
Cheers,
Edgar
www.emphys.com
Hello Marianna,
Please review the section on interpolation functions in the COMSOL Multiphysics v6.2 Reference Manual, starting on page 362. In particular it contains, at the top of page 364, an example of what the data file should look like for a function of two arguments. All manuals are available in the GUI via the File > Help > Documentation menu.
-------------------Jeff Hiller
I understood that Marianna is intending to import a grid format, while the example on top of page 364 is a table. The grid format is shown on page 365 and unfortunately there is no example with numbers. I remember that it took me a little trial and error before I successfully imported a 3D grid a few years ago.
www.emphys.com
Hi all,
Point taken: An example with numbers will be added to the documentation for the next version of COMSOL Multiphysics. Some aspects that also could be clarified: The rows with coordinates for the x, y, and z grid coordinate values (for 3D), under %Grid, should only include the unique values for each coordinate direction and do not have to have the same length (say 10 x values and 6 y values for a 10-by-6 2D grid). The data values, under %Data, should then contain 6 rows with 10 values in each, representing the data values for grid points along the x direction for all 6 y values with one y value for each row. In 3D, you would have to repeat the data in blocks with the y values repeated for each z value to give you at total of (number of y values) x (number of z values) rows.
Best regards, Magnus
Hi everyone, first of all thank you for helping me!
I finally fixed this problem and got the graph shown in the photos which is exactly what I expected.
Now I have another problem related to simulation convergence. I imposed the function int1(x,t) in the magnetic field-point constraint section as mf. By-(int1(x,t)) and I've tried changing some solver settings but it doesn't work.
Do you have any suggestions?
Hi Marianna,
First: I think you have an issue with units and the location of the int1 function. The function is set up with mm and Comsol expects m in the constraint.
Second: The x-axis is ranging 0 ... 100 mm, while your line in the geometry is located -50 ... +50 mm. I changed the constraint expression to: mf.By-(int1(0.001*x+0.05,t)) It may be better to set up the input data in a way that fits the geometry.
Third: In the time dependent solver it is advisable to choose manual time stepping to make sure the solver properly samples the function in the temporal axis. I changed the time stepping to 'Generalized Alpha' with manual stepping and a time step of 1/(f*100). You can check if a larger time step still gives good results.
Fourth: I think the mesh on the constrained lines is not fine enough to properly sample the spatial dimension of the constraint. I changed it to equidistant distribution with 1000 elements. Maybe less works as well.
The model solves with those changes, and you will see if the results match your expectations.
Cheers Edgar
www.emphys.com
Hi Edga, thanks for the suggestions. Some I was able to implement, others I didn't. By chance you would be able to share my model with these changes made.
Best, Marianna
Sorry, I didn't save the test model. Where are you having issues?
www.emphys.com
Hi Edgar,
I have a preoblem with this part:
*I changed the time stepping to 'Generalized Alpha' with manual stepping and a time step of 1/(f100). *
I didn't find the setting Generalized Alpha.
Go down along the Solver Configurations to the Time Dependent Solver and expand the tab 'Time Stepping'. Change the Method from BDF to Generalized Alpha, the Steps taken by solver to Manual and the Time step to 1/(f*100).
This approach typically works well on periodic waveforms.
Good luck!
www.emphys.com
