Laminated core
Hello everyone,
I’m interested in simulating the induction heating of an object that occurs with the help of a rectangular coil that is placed above it. The problem that I’m facing is that I want to increase the produced magnetic field by using a soft iron core (U shaped and around the coil) that is laminated into 1665 parts and each one of them is insulated so that they won’t interact with each other. Is it possible to do this with Comsol? I would be grateful if someone could explain me how.
Thank you in advance,
Rosa
6 Replies Last Post 20 déc. 2012, 14:39 UTC−5
Posted: 1 decade ago 6 déc. 2012, 01:00 UTC−5
It is certainly possible, but you will get a terribly complex and large mesh if you are in 3D, so you would probably need a cluster.
On the other side you can get reasonably close if you apply some good physics engineering tricks to your model, at least I would try this: use an anisotropic model of your iron, it will basically be for the conductivity, that should be set close to "0" across the laminated direction. The lamination is mainly for the Eddy currents, no ? and it should have little effect on the magnetic field
Hi It is certainly possible, but you will get a terribly complex and large mesh if you are in 3D, so you would probably need a cluster. On the other side you can get reasonably close if you apply some good physics engineering tricks to your model, at least I would try this: use an anisotropic model of your iron, it will basically be for the conductivity, that should be set close to "0" across the laminated direction. The lamination is mainly for the Eddy currents, no ? and it should have little effect on the magnetic field -- Good luck Ivar
Posted: 1 decade ago 7 déc. 2012, 08:36 UTC−5
OK I will try it! Thank you very much
Rosa
OK I will try it! Thank you very much Rosa
Posted: 1 decade ago 20 déc. 2012, 03:13 UTC−5
Dear Ivar,
I've tried to define the conductivity of the iron as anisotropic but comsol changes my option on its own to the other available options (isotropic,symmetric, diagonal). Do you have any idea why is this happening? I'm working in 2D.
Dear Ivar, I've tried to define the conductivity of the iron as anisotropic but comsol changes my option on its own to the other available options (isotropic,symmetric, diagonal). Do you have any idea why is this happening? I'm working in 2D.
Posted: 1 decade ago 20 déc. 2012, 03:21 UTC−5
it could be that in 2D axi you can anly use a limited set of anisotroy cases, to respect the 2D-axi symmetry.
Are you in 2D-axi ?
Hi it could be that in 2D axi you can anly use a limited set of anisotroy cases, to respect the 2D-axi symmetry. Are you in 2D-axi ? -- Good luck Ivar
Posted: 1 decade ago 20 déc. 2012, 03:25 UTC−5
actually I'm in 2D because the coil is a straight one.
Hello, actually I'm in 2D because the coil is a straight one.
Posted: 1 decade ago 20 déc. 2012, 14:39 UTC−5
but then anisotropy should apply (I can select anisotropic material in 2D and 2D - axi (v4.3a) ;)
Hi but then anisotropy should apply (I can select anisotropic material in 2D and 2D - axi (v4.3a) ;) -- Good luck Ivar
