5 déc. 2012, 01:18 UTC−5
if you define an integration over a domain, and use the Bolean operand "(My_Var < My_value)" I would expect to get the total volume of the region obeying the Bolean condition, no ?
In COMSOL a 3D integration is by default: integrate_over_my_selections_of_Domains(argument*dx*dy*dz)
while the dx*dy*dz is "implicit" (or it might be 2*pi*r*rd*dz in 2D axi)
7 déc. 2012, 01:25 UTC−5
HI Ivar
Thanks I hadn't thought of using a boolean expression.
Works perfectly of course
Thanks again
Dan
HI Ivar
Thanks again
Dan
7 déc. 2012, 02:58 UTC−5
one warning, do not use Boolean on average operators, as the normalisation is not taking into account the boolean expression and you get too low values. Then its worth to write out the two integration fully, both with the same boolean expression in the numerator and de-numerator of the average expression
