Evaluating Volume in Livelink
I came with the same question about evaluating the volume of my geometry in Livelink,
One can evaluate the volume right after running the model (not before) using
model.result.numerical.create('meas1', 'MeasureVolume'); model.result.numerical('meas1').selection.all; %or other selection depending on your problem model.result.numerical('meas1').setResult; current_volume = model.result.numerical("meas1").getReal
Otherwise, if one wants to evaluate to evaluate the volume before running the model, consider for instance that you want to create a geometry with a desired volume within a loop (see for instance https://www.comsol.com/blogs/how-to-create-a-randomized-geometry-using-model-methods/), the previous method is not practical. I have done this via the mesh node.
current_volume = mphmeshstats(model,'mesh1').volume
If one have several meshes then, one has to sum up them all.
Is there other solution, perhaps at the geometry node?
2 Replies Last Post 13 déc. 2023, 12:06 UTC−5
Posted: 1 year ago 13 déc. 2023, 10:41 UTC−5
You can measure the volume of a domain WHILE you run the model by integrating 1 in that domain of interest in a nonlocal coupling. This can be done directly in COMSOL. I guess there is an option to do it over the Livelink, but I am not using that.
Cheers Edgar
Edgar J. Kaiser
emPhys Physical Technology
www.emphys.com
You can measure the volume of a domain WHILE you run the model by integrating 1 in that domain of interest in a nonlocal coupling. This can be done directly in COMSOL. I guess there is an option to do it over the Livelink, but I am not using that. Cheers Edgar
Posted: 1 year ago 13 déc. 2023, 12:06 UTC−5
Updated: 1 year ago 13 déc. 2023, 11:52 UTC−5
You also don't need to solve or (resolve) any physics. You can "get initial values" (or "update solution") instead to compute (or recompute) a quantity that is not impacted by the solution of the physics.
Jeff Hiller
You also don't need to solve or (resolve) any physics. You can "get initial values" (or "update solution") instead to compute (or recompute) a quantity that is not impacted by the solution of the physics. Jeff
