Edgar J. Kaiser
Certified Consultant
8 months ago
8 déc. 2023, 12:19 UTC−5
Hi Matthias,
the mesher completes when I set the it to 'finer'. However, it throws a few warnings and shows the locations.
You may want to check those spots for geometry errors. CAD imports are often not optimized for meshing and have small inconstistencies that do not disturb for manufacturing but kill a mesher.
You can run the model despite the warnings of course and see if it looks reasonable.
Cheers
Edgar
Edgar J. Kaiser
emPhys Physical Technology
www.emphys.com
Hi Matthias,
Cheers
Edgar
8 months ago
8 déc. 2023, 13:40 UTC−5
Hi Matthias,
Cheers
Edgar
Hi Edgar,
thanks for your answer!
That's weird though because just running the mesher with the setting "finer" does not compile for me.
I get the following error:
Failed to generate mesh for domain.
- Domain: 5
Failed to respect edge element on geometry edge.
- Edge: 622
Failed to move mesh point in domain.
- x-coordinate: 8.9935
- y-coordinate: 8.70001
- z-coordinate: -0.411481
Cheers,
Matthias
>Hi Matthias,
>Cheers
>Edgar
Hi Edgar,
> - Domain: 5
> - Edge: 622
Cheers,
Matthias
Edgar J. Kaiser
8 months ago
8 déc. 2023, 13:41 UTC−5
Updated:
8 months ago
8 déc. 2023, 13:49 UTC−5
Sorry, I was using fine, not finer. I guess you won't get around fixing the geometry. Look at the coordinates the mesher errors or warnings point at.
Edgar J. Kaiser
www.emphys.com
8 months ago
8 déc. 2023, 15:32 UTC−5
Updated:
8 months ago
"Fine" is also not working for me.
Hm, anyways, my problem is that I don't know how to fix the geometry. I know where the error is but what would I have to change at the given error? It says it can't move the mesh point in the domain but that doesn't really tell me what is wrong with the geometry.
Edgar J. Kaiser
8 months ago
8 déc. 2023, 16:07 UTC−5
It can be many things. Intersections, small discontinuities, sliver faces, etc. I saw many chamfers. You probably need to check in the CAD source. If you have the Design Module you can try the repair functions. I cannot afford the time to analyze your geometry in detail. Try to simplify as far as possible and avoid small features that don't affect the simulation.
Edgar J. Kaiser
www.emphys.com
8 months ago
9 déc. 2023, 07:11 UTC−5
Alright, I'll try!
Thanks a lot for your help :)
Alright, I'll try!
