Failed to evaluate variable jacobian - using a step function
Hi every one,
Im trying to put a BC (volumetric flow rate) in my model as a step function. But the following error occur:
Failed to evaluate variable Jacobian.
- Variable: step1
- Geometry: 1
- Point: 2
anyone know how can i solve?
best regards,
Geovani
1 Reply Last Post 19 nov. 2012, 05:58 UTC−5
Posted: 1 decade ago 19 nov. 2012, 05:58 UTC−5
you must have defined a value or function that cannot be derived (Dirac function or other). be sure you use a continuous BC expression
Hi you must have defined a value or function that cannot be derived (Dirac function or other). be sure you use a continuous BC expression -- Good luck Ivar
