Dilute species transport concentration condition
I wonder why the "Concentration" condition in the dilute species transport model is of type "boundary" and not "domain", since its unit is in "Mole/Volume". Why does this make sense? How should this be regarded?
Thanks for any input on this.
3 Replies Last Post 19 nov. 2012, 02:10 UTC−5
Posted: 1 decade ago 17 nov. 2012, 05:12 UTC−5
I agree a concentration density on a boundary seems strange (I'm not by ma COMSOL WS so I cannot check) but my first thoughts would e that on boundaries we defne fluxes or constant values.
Now it happens that a flux is ((myvalue/distance)/surface) which happens to give the same units as a (myvalue/volume) but it is in fact a flux per surface variable
Could tha explain your issue ?
Hi I agree a concentration density on a boundary seems strange (I'm not by ma COMSOL WS so I cannot check) but my first thoughts would e that on boundaries we defne fluxes or constant values. Now it happens that a flux is ((myvalue/distance)/surface) which happens to give the same units as a (myvalue/volume) but it is in fact a flux per surface variable Could tha explain your issue ? -- Good luck Ivar
Posted: 1 decade ago 18 nov. 2012, 14:10 UTC−5
Ok, so instead of thinking of what concentration to assign to that boundary, i should rather consider the flux at the boundary?
Posted: 1 decade ago 19 nov. 2012, 02:10 UTC−5
Now back on my WS and checking the help file, I understand it not as a constant flux (the per second is missing to), but a infinite reservoir of given concentration, this applies for inflow, as for open boundary
if you check the boundary equations: inflow fixed the concentration on the boundary to the one of a fictitious reservoir on the external side. Outflow, defines a normal flux, but does not fix it in absolute, while open boundary allows for a normal concentration to leave, but a constant concentration to enter
The Flux BC set a flux per sec
Hi Now back on my WS and checking the help file, I understand it not as a constant flux (the per second is missing to), but a infinite reservoir of given concentration, this applies for inflow, as for open boundary if you check the boundary equations: inflow fixed the concentration on the boundary to the one of a fictitious reservoir on the external side. Outflow, defines a normal flux, but does not fix it in absolute, while open boundary allows for a normal concentration to leave, but a constant concentration to enter The Flux BC set a flux per sec -- Good luck Ivar
