Rotation angle in rigid connector
In Solid mechanic problem, I made a model using a rigid connector between boundaries (as attached figure). The prescribed angle of rotation to the z axis is set 1 (rad). After the computation, the derived value for the rigid body rotation to the z axis (solid.thz_rig3) is just 0.95885 (rad). Why the values are different and how to have the derived value equal to 1 (rad) as the prescribed value?
Thank you!
0 Replies Last Post 27 sept. 2023, 03:18 UTC−4
Hello An Nguyen
